chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on Oct 28, 2010 16:26:04 GMT 1
can someone please confirm petrol to/2 stroke oil ratio i am going to go the petroil route however i had read 25 to 1 ,30 to 1 as the rule with a full tank of petrol how much oil is best tvm
Post by lcowner on Oct 28, 2010 16:29:25 GMT 1
i asked this about full ank but depends if ur tank has filler or not!30 to 1 i think is whats recommended m8
Post by oldelsieboy on Oct 28, 2010 17:46:24 GMT 1
40:1, 25ml of oil per litre of petrol
OEB
chorltoncumrd
Post by chorltoncumrd on Oct 28, 2010 18:17:32 GMT 1
40:1, 25ml of oil per litre of petrol OEB cheers m8
Post by seanrd on Oct 28, 2010 18:48:58 GMT 1
To make matters worse i run 30-1 in the TZR i fill up 10 liters and chuck in 300ml of TTS. Don't forget you might need to jet up aswell
Post by bare on Oct 28, 2010 19:08:08 GMT 1
No place to economise. Oil is still wayyy cheaper than pistons/bores... a serious consideration, as these engines can be fragile if you use them harder than for shopping. Especially so when rebuilt using NON oem parts. Don't believe any of this ? You will :-) Besides it's been proven that decent Fuel and lots of oil produces HP. I use 25:1 as a minimum.
chorltoncumrd
Post by chorltoncumrd on Oct 28, 2010 22:45:04 GMT 1
so that's sorted then deffo 25 to 1 with a touch of 30 to 1 with a suggestion no smidgen of 40 to 1 thanks for all the help and advice much appreciated just off to refit the pump ;D
