Post by lcowner on Oct 26, 2010 18:35:30 GMT 1
just received delivery of a koso digital dash db02r today problem is im crap with electrics.i know thers someone on here has 1 fitted if they can give me step by step where all the wires go to???its for a 4lo right 1st ly:power wire plug coming from dash unit it has 3 x wires about 12" long: 1x brown-wud this go to the swicthed live (brown from ignit.)? 1 xred (which it says is 12v + pole connect to 12 v battery -not sure where this goes 1x green-wud this go to the big black earth this is just the start ;D this shud be lots of fun ;D ;D if i can get power to unit i think i can manage the rest cheers chaps
Post by lcowner on Oct 26, 2010 19:31:02 GMT 1
bump
Post by lcowner on Oct 26, 2010 20:52:02 GMT 1
yeah gaz instructions but i wish i had instruction s for the instructions!lol right i connected red to the brown wire from ignition(swicthed live) connected green to earth i did get power to the dash but no back light(on dash that is) so i persume brown would be permanent live(fr clock when parked up) but which wire do i connect this brown wire to?surly i dont have to run a wire all the way back to + on battery itself......................
thanks so far
Post by lcowner on Oct 26, 2010 20:57:10 GMT 1
bumpty bump
Post by mellow on Oct 26, 2010 21:18:35 GMT 1
careful m8 ul do urself damage with all that bumping into stuff
Post by lcowner on Oct 26, 2010 21:21:05 GMT 1
;D ;D ;D
Post by lcowner on Oct 26, 2010 21:35:47 GMT 1
main red from battery goes up into igintion 1st ..then switches to brown via ignition....so try that mate.. was ther nowt in the box??? or on website at all??? how they sell with no user instructions theres a wiring diagram gaz but i hate electrics and dunno how to read wiring diagrams
Post by lcowner on Oct 27, 2010 8:17:37 GMT 1
thanx garry but i got sorted with ur advice ..........using ur advice 3 up ^^^.i have power going to it via ignition swicth and back light working now so i think im ok now m8 thanx a million!!! no doubt i be back on here later looking for more advice on the rest of it ;D
Post by lcowner on Oct 27, 2010 19:05:43 GMT 1
told ya i be back!!how the hell do i set up the rpm??this is what i have left: lets call left to right 1-9 1-speed sensr 2-speed sensor bkt 3-magnets for sensor to pick up signal on wheel,wer im suppose to put these i dunno-glue them onto disc or head of disc bolts? 4+5 are exactly the same and one end plugs into dash unit 6+7 same one is for water temp and other fuel,which i wont use 8+9-rpm leads ive been told to use the wire 8(2nd from right),now the green bullet connector goes to dash unit,the female spade(insulated) goes to - side of coil.............what im left with is 'o' connector thingy and a spade connection i persume 1 of these has to be wired around plug itself and other well i dont f**kin know...........any help would be great i did email koso and asked him which cable i use for rpm and he replyed with this:(wire type 'b' is wire 8 second from right) ''The RPM wire has a bullet connector and is paired with the black fuel gauge ware coming out of the rear of the gauge, suggest you use it with wire type B connected to negative side of coil, then st up the number of cyinders the coil is driving as per the instructions leaflet'' CLEAR AS f**kIN MUD ;D
Post by lcowner on Oct 27, 2010 20:13:20 GMT 1
yeah i think i can manage the rest but sorry which is negative on coil(i feel like a right numpty!)?sorry for all this bolloxing m8 about................
Post by lcowner on Oct 27, 2010 21:15:17 GMT 1
this is what koso said wer wires go for rev counter to work: bullet end-goes to dash – Yes that’s correct insulated female spade-goes to negative side of coil under tank – Yes that’s correct male spade connector- to original wire that connected to negative side of the coil 'o' type connector- not usually connectedso pissed off now going to f**kin bed.................
Post by lcowner on Oct 27, 2010 21:20:34 GMT 1
Post by lcowner on Oct 28, 2010 13:00:58 GMT 1
just wrapped wire around plug lead as advised from a mate who works in a bike shop and rpm works fine now..........................i dont undersatnd y instructions ect are so complliacated these days ffs thanx gaz for all your help
Post by lcowner on Oct 29, 2010 23:50:38 GMT 1
appreciate it m8
Post by mellow on Oct 30, 2010 12:10:38 GMT 1
YEAH!!!! ;D
Post by lcowner on Oct 30, 2010 13:46:32 GMT 1
yeah yeah
