Post by Deleted on Oct 23, 2010 15:13:09 GMT 1
bike wont pull over 90 in top. Seems to rev okay in lower gears but dont feel power band pull like i remembered from RD400(over 25 years ago). i've only had the bike a few weeks. Fitted new plugs , air filter and blown out carbs. Fitted new PV cables last night, servo cycles and backs off when on tick over. Could it be the valves need cleaning. Thanks in advance Jim
Post by twostroker on Oct 23, 2010 15:52:14 GMT 1
check your gearing,mine was like that till i fitted a 1 tooth smaller front sprocket now ive seen the speedo needle go slightly off the 120mph clock and it revs out nicley in all gears with out feeling over or under geared
Post by Deleted on Oct 23, 2010 22:00:18 GMT 1
I'll check the gearing tomorrow but even if the the gearing is low wouldn't still feel a distinct powerband
