Post by pepsisteve on Oct 22, 2010 12:58:04 GMT 1
can anybody run by me what needs to be done to do the 375 conversion, i know you have to use DT pistons, but its stuff like the head etc. thanks
steve
Post by winnerevo1 on Oct 22, 2010 22:16:29 GMT 1
Don't know. ;D
The only part of the conversion i know of is the bottom of the barrels need machining. Quite a bit has to come off because the ones i've seen have had most of the cast "347cm3" machined off.
Not worth doing if you've got a decent pair of low over bore barrels.
