chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on Oct 21, 2010 13:01:05 GMT 1
I have just checked my generator /dynamo on my bike the readings show the pulsar coil is f* dead. does anyone know where i can get one (pulsar coil) are they expensive in regard to buying a secondhand generator off evilbay. i have 3generators and all of them are the same on the pulsar coil dead!! however all other readings are within tolerance. advice and guidance please
monkfish
NaNaNaNaNaNaNa Argos
Post by monkfish on Oct 26, 2010 1:02:25 GMT 1
Ive just had this problem. When I took the stator plate off I found that the pulsar coil wire was crushed between the stator plate and the crank case. Once pushed back into the recess where it belongs the problem was solved. After checking that you still think its goosed you could have a word with West Country Windings.
