Post by andygraham on Oct 16, 2010 18:33:41 GMT 1
hi struggling putting the kickstart back together LC. little ball and spring.any tips on how to put back together any help very much appreciated before the bearing disappears forever
Post by johnlc on Oct 16, 2010 18:43:37 GMT 1
Can you tape the ball into position then take tape out after just a thought
Post by andygraham on Oct 16, 2010 18:45:35 GMT 1
the ball isnt so much the problem its a small spring that comes with the kit dont know where it goes must be knack to it just have to wait and see what the boys come up with
Post by andygraham on Oct 16, 2010 19:00:10 GMT 1
managed to sort it the hole where the spring goes didnt look very deep on closer inspection found the problem flirted out half an old spring that was stuck in went together easily after that thanks
Post by bare on Oct 16, 2010 19:07:31 GMT 1
Did the 'repair' actually work? Asking , as on mine the shaft wear /play seemed to defeat my repair efforts.
Post by lcowner on Oct 16, 2010 22:44:16 GMT 1
yes it works vey well,i did exactly the same as andy nearly lost a f**kin eye in the process!!!left old sprng in...........
Post by andygraham on Oct 19, 2010 11:12:10 GMT 1
there is a little movement.like you say the actual kick start wears through time. its a lot better tho. make sure theres a lot of open space for the ball bearing as it jumps out of your hand. the old on had a flat spot had me goggles on during the flirting out process ;0
