maxman
Post by maxman on Oct 10, 2010 8:56:30 GMT 1
Hi ALL...I have just put my rebuilt RZV500R back on the road and something is amiss!! 1, RUNS FINE ON 4 POTS TICKING OVER 2, When actually running along its slugish and not rite, very poor performance and not firing properly... 3, The rear numberplate is coating up in thick oil from the pipes so badly, you cant see the numbers??
Motor has been striped and new pistons fitted barrels honed out and a new outer main bearing was fitted....by a good mechanic using manuals...
Any ideas? cheers peeps..
Post by oldelsieboy on Oct 10, 2010 10:41:06 GMT 1
Hi ALL...I have just put my rebuilt RZV500R back on the road and something is amiss!! 1, RUNS FINE ON 4 POTS TICKING OVER 2, When actually running along its slugish and not rite, very poor performance and not firing properly... 3, The rear numberplate is coating up in thick oil from the pipes so badly, you cant see the numbers?? Motor has been striped and new pistons fitted barrels honed out and a new outer main bearing was fitted....by a good mechanic using manuals... Any ideas? cheers peeps.. Sounds like oil pump settings, what is the condition of the spark plugs? OEB
Post by masterbill on Oct 10, 2010 20:13:12 GMT 1
Hello,
What did you set the carb float level to 21 or 24mm?
maxman
Post by maxman on Oct 10, 2010 21:57:30 GMT 1
hI,,They were new plugs...will check pump....cant be much I dont think..cheers folks..
