seals
Oct 8, 2010 20:01:25 GMT 1
Post by powervalve126 on Oct 8, 2010 20:01:25 GMT 1
anybody change fork seals on a 86 pv is it a big job thanks in advance
seals
Oct 8, 2010 20:07:10 GMT 1
Post by Tone on Oct 8, 2010 20:07:10 GMT 1
Just done mine on the LC2 had to order a long 6mm hexagon/socket to get at the damper rod bolt at the bottom of the forks. Tone.
seals
Oct 8, 2010 20:18:45 GMT 1
Post by powervalve126 on Oct 8, 2010 20:18:45 GMT 1
thanks m8
seals
Oct 8, 2010 20:59:07 GMT 1
Post by mellow on Oct 8, 2010 20:59:07 GMT 1
DID MY f2 ones few years ago.pretty simple.as tone says u need a long hex bit for damper bolt. If you have trouble gettiin it undone i popped mine to local bike shop who undid it in about 2 seconds with air ratchet gun thingy.apart from that str8 forward
seals
Oct 8, 2010 20:59:21 GMT 1
Post by scott on Oct 8, 2010 20:59:21 GMT 1
not to hard m8,just watch how they come apart and put em back the same,i would use genuine seals tho as i fitted some pattern 1's and the leaked really bad,put gen in and it's all good so ended up spending more in the end. to get the stantion out of the ally lower u need to pull apart really hard to get the old seal out
seals
Oct 8, 2010 21:36:54 GMT 1
Post by powervalve126 on Oct 8, 2010 21:36:54 GMT 1
thanks scott
