monkfish
NaNaNaNaNaNaNa Argos
Post by monkfish on Oct 8, 2010 18:32:02 GMT 1
is it a simple case of unpluging the rh switchgear to bypass the cutout switch? on my 4lo
Post by pepsisteve on Oct 8, 2010 19:54:28 GMT 1
if you unplug it i'm sure the circuit will then be open so you will have to bridge the wires across the 2 contacs that do the kill switch. if you do this you are better off soldering the join to make sure its nice and vibration proof!
monkfish
Post by monkfish on Oct 9, 2010 10:34:09 GMT 1
Cheers Steve, im just trying to eliminate it from the search as to why my engine just stopped and wouldnt start again. I managed .2 of a mile on the freshly built motor before it stopped Its getting fuel, the plugs are not fouled. I figure its got to be electrical. I did put a block connector on the stator, could be that, although i did solder the wires in place and not just crimp.
Post by scott on Oct 9, 2010 10:51:47 GMT 1
as steve says m8 you'll have to join the 2 wires that do the kill switch
monkfish
Post by monkfish on Oct 11, 2010 1:07:06 GMT 1
Cheers Gaz, ive eliminated the kill switch as the cause, its working fine however I believe it to be the pulser coil as i can only get a reading of .8ohm between the white/red wire and the black earth coming from the stator, just had it rewound by west country so they can have it back. How do I test the cdi? cheers Andy
monkfish
Post by monkfish on Oct 11, 2010 11:50:44 GMT 1
Oh deep joy, ive found the problem ;D The pickup wire (white/red) was trapped inbetween the stator plate and the crankcase. When i removed the stator plate I got a reading of 84.9ohm for the pulser coil. I have to say that I spoke to west country windings this morning and they were extreamly helpful and spot on with their diagnosis of what the problem might be. Thanks fellas, today is a good day
Post by mellow on Oct 11, 2010 15:54:37 GMT 1
Excellent news m8.Gr8 when its such a simple fix.now get out and enjoy ;D
monkfish
Post by monkfish on Oct 11, 2010 19:21:56 GMT 1
Excellent news m8.Gr8 when its such a simple fix.now get out and enjoy ;D lol. its not quite as easy as that. I went up the road for a test ride and applied some rear brake at which point the brake tension bar ripped apart at the swing arm mounting point and jammed its self round the back wheel. I dont think I tightened it up properly...what a nob I got a std bar i can put on and so its back to runnin it with no back brake ;D ;D
Post by mellow on Oct 11, 2010 19:35:31 GMT 1
wot a knob!!!!! ;D
monkfish
Post by monkfish on Oct 11, 2010 20:32:27 GMT 1
wot a knob!!!!! ;D there is an echo in here
Post by scott on Oct 11, 2010 21:38:24 GMT 1
as steve says m8 you'll have to join the 2 wires that do the kill switch tbh mate if you short out the switch wires you will be making the KILL circuit LIVE!! disconnect the black with single white trace to the cdi (kill wire) and it should spark....however do not run the bike with is removed as you wont be able to stop it unless ya stall it.... there is also kill circuit via ignition as well.... no spark is usually stator or cdi related... unplugging the kill switch will bypass it and will not function ....shorting the wires will make it work so DO NOT do that!!! ok sorry monkfish,just would have thought the circuit would have to be connected together for it to work,i'll keep out of electrical probs i think
monkfish
Post by monkfish on Oct 12, 2010 1:06:07 GMT 1
tbh mate if you short out the switch wires you will be making the KILL circuit LIVE!! disconnect the black with single white trace to the cdi (kill wire) and it should spark....however do not run the bike with is removed as you wont be able to stop it unless ya stall it.... there is also kill circuit via ignition as well.... no spark is usually stator or cdi related... unplugging the kill switch will bypass it and will not function ....shorting the wires will make it work so DO NOT do that!!! ok sorry monkfish,just would have thought the circuit would have to be connected together for it to work,i'll keep out of electrical probs i think No worries mate, I was barking up the wrong tree anyway. See you at Stafford on sunday, wont be too early cos im giging on saturday night Rock on..Andy
Post by scott on Oct 12, 2010 21:06:20 GMT 1
ok sorry monkfish,just would have thought the circuit would have to be connected together for it to work,i'll keep out of electrical probs i think No worries mate, I was barking up the wrong tree anyway. See you at Stafford on sunday, wont be too early cos im giging on saturday night Rock on..Andy ok andy av a good 1,i was sposed to be goin to see guns and roses on the sunday nite after the staff show but don't think i'll be back in time so i think me brothers goin in my place.
