Post by pepsisteve on Oct 6, 2010 13:57:23 GMT 1
just put a 350 top end on my lc with 4LO 01 carbs on as well. carbs were fully stripped and cleaned by a local company and i have had an air line in all the holes and everything seems fine. pilots are 22.5, mains are 220, needles are on the middle clip, air screws are 1.5 turns out, stock pipes and reads, porting etc. the problem i have is it is very rich as you get on the throttle, starts first/second kick and ticks over lovely, once you pull away it is clearly rich but you can ride through it and then it revs fine.
any ideas?
Post by pepsisteve on Oct 7, 2010 10:09:25 GMT 1
will do mate, i am going to drop the size of the piots and go from there, i will pm you if i sort it.
steve
Post by spondonchris on Oct 7, 2010 10:51:07 GMT 1
Raise the needle a notch first.
