Post by nikfubar on Oct 5, 2010 22:59:31 GMT 1
Just got an ultrasonic cleaner, anyone know what the best thing to use for cleaning carbs Just put Swarfega oil & grease remover in it to clean my power valves & it worked a treat but not sure what to use on delicate items Thanks ;D
Post by garyt on Oct 5, 2010 23:04:14 GMT 1
i used 1 part washing up liquid to 5 parts cold water
Post by JonW on Oct 6, 2010 13:36:02 GMT 1
just hot water (as hot as the hot tap will run has been fine for me but your tap may be hotter) and some washing up water. Use a toothbrush on the dirty outsides before you start and then use the cleaner and change the water as needed... also dont ever put your fingers in when its running... that tingling feeling is your finger nerve endings dying, or som ive been told...
Post by nikfubar on Oct 6, 2010 14:13:51 GMT 1
I PUT MY FINGER IN IT YESTERDAY & watched the dirt come off
chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on Oct 6, 2010 15:55:52 GMT 1
Post by nikfubar on Oct 6, 2010 16:11:26 GMT 1
Post by johnlc on Oct 6, 2010 19:11:22 GMT 1
I PUT MY FINGER IN IT YESTERDAY & watched the dirt come off Better start calling you stumpy then Fishing line for pushing through the tiny jet holes is good too I use fishing line for the pilots and nozzles for clearing them out if they wont blow through
Post by nikfubar on Oct 7, 2010 8:31:10 GMT 1
What are the things to look for in a good ultrasonic cleaner i've heard alot of them mention in the forum but being honest i know nothing about them. can you clean electrical wiring for example Get a medical grade one such as this www.ultrawave.co.uk/products.php?id=15&cat=1&prod=48expensive but they work, I paid £110.00 for a second hand one You can clean anything that won't be damaged by immersion in liquid such as electronics or your FINGERS
scoobysal
If it hurts, you know ya made it.
Post by scoobysal on Oct 7, 2010 15:54:10 GMT 1
I have a small one for cleaning jewellery in and just put water in, doesnt even have to be warm. You wont damage nerve endings in them either.
Post by mick1664triumph on Oct 7, 2010 16:23:00 GMT 1
Hi All, I used this site www.6mmbr.com/ultrasonic.html worked for me I also payed out for proper ali ultrasonic cleaner and thought that was c***p like nfurbar says you need to pay good money for the machine though.[ img][/img]
Post by robmoon on Oct 7, 2010 16:47:51 GMT 1
Mick, What cleaning solution did you use to get that result with the carb?
Post by mick1664triumph on Oct 7, 2010 16:53:29 GMT 1
Small amount of white Vinegar and washing up liquid similar to the one on the web link I have posted
Post by JonW on Oct 8, 2010 6:51:03 GMT 1
Are people saying that that tingling doesnt damage your nerve endings? Im not being funny, just that is what i was told by someone who used them a lot.
Post by JonW on Oct 8, 2010 6:59:32 GMT 1
Hi All, I used this site www.6mmbr.com/ultrasonic.html worked for me I also payed out for proper ali ultrasonic cleaner and thought that was c***p like nfurbar says you need to pay good money for the machine though. I have the same cleaner that guy used for his old bullet casings, but I use it for watch parts. It works really well on dirty bracelets (crusty with a blend of human skin, dust and body oils/hand creams etc) with warm water with a dash of washing up liquid. I assumed that was similar to carb grease and it worked ok on some parts that i did, but will try some vingear and other things now you guys have said that. One thing thats great about this type of cleaning is that it gets in all sorts of places that you cant put a brush into or would ruin with a solid probe etc.
scoobysal
Post by scoobysal on Oct 8, 2010 12:29:43 GMT 1
Are people saying that that tingling doesnt damage your nerve endings? Im not being funny, just that is what i was told by someone who used them a lot. I have used them a lot in theatres where i work. They used to be used to clean instruments. I guess there are different ones for different jobs and maybe the ones you have been told about do cause damage. The ones i have used dont.
Post by JonW on Oct 8, 2010 23:34:24 GMT 1
I knew that was comin when i wrote it... shoulda known better...
Post by Deleted on Oct 10, 2010 19:53:34 GMT 1
What sort of money would you pay for a cleaner that would do carbs !
Post by nikfubar on Oct 15, 2010 23:26:25 GMT 1
Got some carb cleaner, works well as theres loads of crap in the bottom of the tank. And after Also doing a bit of nickel plating, fitted a drain plug to the pump cover & made a bracket for me hydraulic clutch. Shiney shiney ;D
Post by mellow on Oct 16, 2010 13:22:13 GMT 1
works alright that diy plating stuff does it nik?where u get it?Frosts?
Post by nikfubar on Oct 16, 2010 13:50:35 GMT 1
Post by mick1664triumph on Dec 3, 2010 15:40:12 GMT 1
Yea i have used his stuff with good results pictures of me F1 are on his site
