Post by stinkerd on Sept 28, 2010 6:38:10 GMT 1
Hello, My name is Marcel de Jong from the Netherlands. At the moment I'm finishing a RGV swingarm conversion for my RD350 4LO. Can anybody recommend me what tail hight I could use best? See attached picture for reference. Probably your Dutch is not soo good ;D but you can follow the rebuild here. rd350.motormuizen.nl/phorum/read.php?4,154924 thank's in advance! Attachments:
Post by Norbo on Sept 28, 2010 6:44:07 GMT 1
Its up to you what you look the look of most just stay with the standard one but sink it in so its not so stand outy
Post by scott on Sept 28, 2010 9:27:12 GMT 1
welcome marcel,did u mean tail light or tail height.nice lc by the way m8
Post by stinkerd on Sept 28, 2010 9:37:51 GMT 1
I meant tail Height, measured from tail Light to floor;D
Post by scott on Sept 28, 2010 13:34:30 GMT 1
I meant tail Height, measured from tail Light to floor;D there is afew chaps with this conversion m8 and i'm sure someone will give you a measurement,just might take afew days
Post by scott on Sept 28, 2010 13:37:37 GMT 1
just looked a bit further down the page jessy03 has rgv banana arm in "finally finished after 4 years" he should beable to help m8
Post by stinkerd on Sept 29, 2010 12:33:49 GMT 1
Thank's btw!
Post by jessy03 on Sept 29, 2010 22:12:44 GMT 1
Hi, The black uses a 125lc shock and the red/white one use's a SV650 shock. I have measured them and the SV650 shock raises the back by another 10mm over the 125lc shock. I f you need any further pics or dimensions let me know let me know. ATB Jessy
Post by winnerevo1 on Oct 2, 2010 11:57:56 GMT 1
Hello mate, just a quick question about the rear master cylinder. Is the hose fitting/fluid inlet (plastic part fitted into the master cylinder) different to a standard YPVS one? Is the union straighter, as the normal YPVS one is quite angled?
