Post by lcowner on Sept 26, 2010 13:41:52 GMT 1
got meself a set of mint blue spot r1 callipers,apart from brackets is there anything else i need to do the conversion on my 4lo?
Post by kiwivini on Sept 29, 2010 11:31:08 GMT 1
Apart from new hoses should be fine i would assume.
Not sure whether the existing master cylinder would have a big enough bore to work properly but suggest you try it first and see what happens.
I have a thundercat which uses the same calipers so will check to see if the master cylinder bore size is stated anywhere for you.
If you speak to NK racing (they do the brackets) im sure he would know a lot more about this conversion. hope this helps
Post by lcowner on Sept 29, 2010 11:33:48 GMT 1
cheers m8
Post by kiwivini on Sept 29, 2010 22:33:50 GMT 1
Mate checked the underside of the 'cat's master cylinder and it has 14 stamped on it and not much else that makes any sense.
I would assume that means it has a 14mm bore but could be wrong.
cheers
Post by lcowner on Sept 29, 2010 22:54:37 GMT 1
ok i think it will b ok anyway.........
