hondablade
2 wheels ~ 2 Strokes
Post by hondablade on Sept 23, 2010 21:06:16 GMT 1
Which type of exhaust gaskets work the best, im getting oil and shite seeping out of the joint face on mine making a mess on the underside of the bike. Ive got the alloy type gaskets with the asbestos insert on it at the moment but dont seem to be much good. Ive seen alternatives but which are the best?
Its a spring mount setup on manifold brackets btw. Cheers!!
Post by Trubrit on Sept 24, 2010 5:21:40 GMT 1
I Had The Same Problem .Try The Copper Type That Norbo Sells Bit More Money But Did The Trick For Me ......
Post by lcowner on Sept 24, 2010 10:50:56 GMT 1
yes m8 try copper ones ,and are u using the paper gasket also around flange?used both on mine and hey presto there ok now.i just have to get some sealent to sort spueing oil from where the pipes join the flanges now
