cj
Post by cj on Sept 21, 2010 8:56:06 GMT 1
Had all the paint removed from the panels on my LC2, the side panels are black with the mudguard and tail section creamy yellow. I assume that the normal would be all black plastics and these others are fibreglass imposters?
cj
Post by cj on Sept 21, 2010 20:10:11 GMT 1
Well I'm not sure what exploded or burnt first but I sure need a new shed!!!! Damn them panels burn BAD!
Post by bubba on Sept 21, 2010 20:16:28 GMT 1
;D ;D ;D
Post by Shytalk on Sept 21, 2010 20:33:43 GMT 1
Had all the paint removed from the panels on my LC2, the side panels are black with the mudguard and tail section creamy yellow. I assume that the normal would be all black plastics and these others are fibreglass imposters? Actually you assume wrong ;D the mudgaurd and rear section if original plastic are off white yellowish under all the primer, and as rave says you can tell glass fibre by the look, sounds like pukka plastic is what you have. Here's one I prepaired earlier -
cj
Post by cj on Sept 22, 2010 22:44:15 GMT 1
Thanks guys - after having a closer inspection I can see approx' 1cm round indents on the insides so that would reinforce injection molded plastics Great news, onward and upward Regards CJ
