Post by lcowner on Sept 20, 2010 17:33:21 GMT 1
has anyone fitted 1 of norbos belly pans?are they hard to fit any issues with fitting them ect? cheers
Post by lcowner on Sept 20, 2010 19:11:54 GMT 1
bucth is der much room say between the downpipes and the belly,its just my pipes are sitting 1" below normal and im just wondring is will the belly pan fit at all?
Post by lcowner on Sept 21, 2010 8:53:58 GMT 1
dat cud be a problem.........
Post by Norbo on Sept 24, 2010 7:58:35 GMT 1
They fit well with standard pipes microns all speeds but with race pipes some times you need to shave a bit of the front as race pipes tent to come out at more of an angle. and big chamber pipes like lomas will foul the back so you may ned to lower them at the back . The only real problem i have with them is the fidely nut at the back so i just weld it on the bracket so i dont have to hold it and the pan and with my 3ed habd put the bolt thew
