tzer
Post by tzer on Sept 12, 2010 11:42:59 GMT 1
Hi Ive been have problems with oil pump cable routeing? at the pump,where the oil pump return spring conects to the cable wheel it gos through a small hole and into the cable track? mine seems to be sticking into the cable track making the cable run on top of it, rather than sit in the groove, if you see what I mean this gives a cam type effect to the whole shooting match? it needs a good pull side ways to let the cable under it is this norm? thanks
Post by oldelsieboy on Sept 12, 2010 12:04:14 GMT 1
Hi Ive been have problems with oil pump cable routeing? at the pump,where the oil pump return spring conects to the cable wheel it gos through a small hole and into the cable track? mine seems to be sticking into the cable track making the cable run on top of it, rather than sit in the groove, if you see what I mean this gives a cam type effect to the whole shooting match? it needs a good pull side ways to let the cable under it is this norm? thanks Yes, just ease the spring over to allow the cable to seat in the bottom of the pulley, otherwise you will not be able to adjust the pump cable correctly. OEB
