Post by pepsisteve on Sept 10, 2010 15:27:57 GMT 1
over winter my lc (4lo) is going to have some 'tweeks' done to her. the tops part of my forks are a bit rusty and unsightly so i was going to swap over to 31k forks and yokes. what is the difference between the two? are the 31k's a bit bigger because that is what i am after. also can i run the bike with the later pv pipes on it? the ones with the alloy rear cans. doesnt matter if the brackets are different because we do welding at work. the engine is stock i just fancy some of them pipes so i can cut the cans off and put some flanges on the end so i can fit some spare carbon ones off my rgv. cant justify £500 on pipes but i want the old girl to look a bit better, if i want to go fast i go out on the rgv! thanks steve
Post by lcowner on Sept 10, 2010 16:27:50 GMT 1
yes m8u can run 31k forks.you will need to change top and bottom yoke and also front muddy holes are different so u need that aswell. pv pipes will fit on.all u have to do is elongate the hole in the footrest hanger bracket.check out the for sale section m8 all the stuff u need is for sale in the for sale section on here
