Post by robmoon on Sept 9, 2010 22:31:18 GMT 1
Can someone tell me if the throttle and clutch cable should be routed down through the middle of the clock bracket or outside of the bracketon my 4L0?
ta
Post by oldelsieboy on Sept 10, 2010 16:51:04 GMT 1
Can someone tell me if the throttle and clutch cable should be routed down through the middle of the clock bracket or outside of the bracketon my 4L0? ta Clutch cable goes thro' the clock bracket Throttle cable goes under the clock bracket & around the headstock You can find routing diagrams HERE & HERE HTH OEB
Post by robmoon on Sept 10, 2010 21:30:02 GMT 1
Thanks OEB,
Just got to route those cables and re-fit the horn and my 4L0 is back on the road ( the Kenny Roberts one that the nice BOC Gas lorry driver reversed into !!)
Rob
