Post by Deleted on Sept 8, 2010 17:05:18 GMT 1
I am trying to lift off the offside barrel but it is refusing to budge. I am just about pulling the bike off its stand!
I have removed the cylinder head and carb, disconnected the power valves at the centre joint and removed the four retaining nuts from the flange of the barrel. That's it, isn't it?
Any tips for lifting the bugger off?
Post by Shytalk on Sept 8, 2010 17:12:05 GMT 1
Obviously the exhausts are off I'd get a block of wood and use it as a drift and tap around the under edge of the exhaust port.
Post by midlifecrisisrd on Sept 9, 2010 8:45:09 GMT 1
I am trying to lift off the offside barrel but it is refusing to budge. I am just about pulling the bike off its stand! I have removed the cylinder head and carb, disconnected the power valves at the centre joint and removed the four retaining nuts from the flange of the barrel. That's it, isn't it? Any tips for lifting the bugger off? My last motor was like that, the four studs and the barrel holes had corroded and swollen making it a bitch to remove. Abit of heat aroung the studs should help. Rubber mallet job trying to rock it off. Steve.
Post by Deleted on Sept 9, 2010 17:11:15 GMT 1
Yep, the exhausts are off and it's not nipped up.
I'll try all your suggestions. Thanks.
Post by dredge3 on Sept 9, 2010 23:50:37 GMT 1
Try a little WD40 in the suds....plus heat
Post by Deleted on Sept 15, 2010 8:56:40 GMT 1
Update[/u]
The hairdryer did the trick.
I warmed the barrell around the base gasket, gave it a tug and off it popped.
Thanks ;D
