Post by lcowner on Sept 7, 2010 14:42:51 GMT 1
where do these connections go at headlite for 4lo loom?sorry but wiring totally confuses me take it as left to right also there are single wires same place : 1 x lite brown bullet connection. 1x dark brown bullet c. 1 x yell/green bullet c. 1 x black big spade c. 1 x green bullet c. bought this pattern loom off norbs so it must make sense ;D once uv above sorted wat bout these under seat : theres: 1x green+yell bullet 1 x green 1 x black 1 x block connector cheers chaps LC
Post by johnlc on Sept 7, 2010 14:53:04 GMT 1
The brown wire and the yellow/green wire are for the brake switch.The green bullet and dark brown bullet are for the indicators and the black wire should have a triple female socket for the earths for indicators i think ,all the block connectors go in the bottom hole of the headlight to join up with the ignition switch and indicator switches which go in through the top hole
Post by lcowner on Sept 7, 2010 15:17:13 GMT 1
also theres a single blue+pink wire coming from ignition swicth block at headlite end?
Post by johnlc on Sept 7, 2010 15:32:49 GMT 1
In your second pic is the indicator wires and the taillight connector by the look of things
Post by johnlc on Sept 7, 2010 15:37:50 GMT 1
Is your big black spade not a triple bullet socket ,although it does look like a big female spade
Post by lcowner on Sept 7, 2010 15:38:05 GMT 1
dont think it is johnlc caus ive taillight connected up to another block connector,would it be to do with oil tank level.im pre-mix now so............
Post by johnlc on Sept 7, 2010 15:40:34 GMT 1
Could be the oil light indicator which doubles up as the neutral indicator when its selected .I was referring to the spade at the front end of the loom
Post by lcowner on Sept 7, 2010 15:40:38 GMT 1
yes john at 1st i though i was 2 connector but its 3 way alrite m8!!thanx for ur help...
Post by lcowner on Sept 7, 2010 15:49:25 GMT 1
also theres a single blue+pink wire coming from ignition swicth block at headlite end? ?
Post by johnlc on Sept 7, 2010 15:50:36 GMT 1
I can see he tailight connector tucked away in the frame so that is definately the oil sender connector and the green and yellow wire again is the brake light switch for the rear brake
Post by lcowner on Sept 7, 2010 15:52:04 GMT 1
cheers john,last 1 is the blue+pink bullet spare from ignition block connector???
Post by johnlc on Sept 7, 2010 15:57:47 GMT 1
have you got a pic of it
Post by lcowner on Sept 7, 2010 15:59:33 GMT 1
will take pic but will take 10 mins to upload m8 cheers
Post by johnlc on Sept 7, 2010 16:00:41 GMT 1
Thats broadband for you lol
Post by lcowner on Sept 7, 2010 16:09:06 GMT 1
hers the said blue+pink wire its a spare bullet type thats left over wen u connect the block connector to ignition swicth(its on the loom side coming from block connector) its approx 3-4 inches long ;D
Post by johnlc on Sept 7, 2010 16:16:53 GMT 1
What wire in the ignition switch does it pair up with
Post by lcowner on Sept 7, 2010 16:23:32 GMT 1
it pairs with a plain blue(same blue color as in pink+blue above) if u know wat i mean-brite blue
Post by lcowner on Sept 7, 2010 16:24:53 GMT 1
ipairs wit the blue wire u can see coming from middle of bunch of wires above running into loom!!! the last 1 is always the hardest
Post by johnlc on Sept 7, 2010 16:25:11 GMT 1
I have a funny feeling its for the pilot light and the earth from the pilot goes into that triple socket with the indicator earths
Post by lcowner on Sept 7, 2010 16:26:59 GMT 1
wen u say pilot lite wat u mean m8?
Post by johnlc on Sept 7, 2010 16:28:02 GMT 1
The sidelight or parking light
Post by lcowner on Sept 7, 2010 16:29:54 GMT 1
oh rite m8,dat deserves a double karma on me, greatly appreciated .......thank for ur time
