Post by lcowner on Sept 4, 2010 15:16:17 GMT 1
whats the easy way to change my 4lo to take 31k forks?do standard 4lo callipers bolt straight onto 31k??looking for the simpliest easyest way! any advice appreciated chaps ;D
Post by oldelsieboy on Sept 4, 2010 15:39:47 GMT 1
whats the easy way to change my 4lo to take 31k forks?do standard 4lo callipers bolt straight onto 31k??looking for the simpliest easyest way! any advice appreciated chaps ;D Easiest way is to buy a set of 31k forks, complete with top & bottom yokes, remove your 4L0 forks & yokes & fit the 31k forks in their place, they bolt straight on. 4L0 & 31k calipers are they same fitment. OEB
Post by onewheelsenough on Sept 4, 2010 16:09:38 GMT 1
you will need the 31k yokes as well
Post by lcowner on Sept 4, 2010 16:16:26 GMT 1
right anything else?
Post by onewheelsenough on Sept 4, 2010 16:51:45 GMT 1
you may have to get a 31k front mudguard because the mounts on the forks are slightly higher. or you could re drill your mudguard.
Post by lcowner on Sept 4, 2010 18:29:41 GMT 1
cheers m8
Post by lcowner on Sept 5, 2010 19:36:04 GMT 1
wat bout mounts for 4lo ignition swicth to 31k top yoke?
Post by scott on Sept 5, 2010 22:12:42 GMT 1
wat bout mounts for 4lo ignition swicth to 31k top yoke? ignition and clock mounts are the same m8
Post by bare on Sept 7, 2010 23:07:36 GMT 1
The difference on the Muddy mounts is in width not height... add a couple of washers betwixt Fender and 31k fork mounts for an easy/invisible bodge :-)
Post by lcowner on Sept 8, 2010 10:38:13 GMT 1
cheers m8,but ive come across a mint set of 4lo forks now so its just a straight swap without all the hastle...
