Post by lcowner on Sept 4, 2010 10:42:13 GMT 1
Post by kiwivini on Sept 5, 2010 22:03:36 GMT 1
surely there wouldn't be enough clearance to get the motorcross type stand underneath the frame unless you jacked the bike up 1st.
Post by scoobytoo on Sept 12, 2010 15:39:50 GMT 1
surely you would end up resting the exhausts on the stand as they are lower than the bike frame?
Post by twostroker on Sept 12, 2010 22:40:11 GMT 1
surely you would end up resting the exhausts on the stand as they are lower than the bike frame? i used a moto-x stand very similar for my old 125lc and to put it on the stand i just removed the belly pan and exhaust as lets face it you wont be using the bike lift that often,like you said the side stand is in the way so i bonded a a few lenths of 1" by 2" wood on to the stand so it cleared the raised bit for the stand and still fit under the bike easy. i know it sounds a bodge and it didnt look 100% but it was cheap,easy and safe way of lifting my bike up,not sure if it would be so easy with a 350 as it was with a 125 tho as your 4lo will be a bit heavier
