Post by paul8899 on Sept 2, 2010 20:09:00 GMT 1
Hi, got a set of pwk28s off fleabay delivered today and I have a couple of questions about them. There is a powerjet (I think) at the top of the inlet end of just one carb,is this right ? I would of thought that there should of been one on both. Also where does the pipe connect to from the powerjet bit ? And finally, has anyone got any pictures of them installed ?
Thanks
Post by johnlc on Sept 2, 2010 20:52:37 GMT 1
Its not a powerjet but a vac take off for the fuel tap
Post by paul8899 on Sept 2, 2010 22:21:43 GMT 1
Thanks, feel a bit of a tit now
Post by nikfubar on Sept 3, 2010 8:14:05 GMT 1
There you go fella ;D
Post by johnlc on Sept 3, 2010 8:50:52 GMT 1
Most people use them for the oil feed but you need to drill one carb out as it does not have the vac take off fitted ,just fit oil jets there for your oil pump
Post by nikfubar on Sept 3, 2010 9:03:39 GMT 1
See picture above ;D ;D ;D
Post by paul8899 on Sept 3, 2010 14:23:09 GMT 1
thanks for the pictures, it makes it a bit clearer now how much of a difference do these make compared to the standard 31k carbs ? and any info on set up / niggles ? Thanks again
Post by nikfubar on Sept 3, 2010 15:34:20 GMT 1
Post by paul8899 on Sept 3, 2010 20:02:14 GMT 1
thanks, that'll some in handy
