Post by loctite on Aug 30, 2010 17:02:46 GMT 1
as above can you mix these carbs to run successfuly thanks nigel
Post by soccersmyth on Aug 31, 2010 13:38:19 GMT 1
I'd say if you checked the workshop manual ther're similar bar the jets.
So if you used the jets of 350 if you running standard you probably would be ok.
I think this answer might be covered in the carbs and jetting link.
