Post by mellow on Aug 30, 2010 10:17:53 GMT 1
Morning men Am i correct in sayin the Expander Ring should ALWAYS be fitted under the bottom ring The reason i ask is im sure it should but just noticed that the person who was running this bike before me had it fitted under the top ring
Post by mick1664triumph on Aug 30, 2010 16:46:23 GMT 1
I have put mine in the bottom ring hope they will be ok
Post by mellow on Aug 30, 2010 21:56:30 GMT 1
i have them in my F2 mick.been fine up till now and its been thrashed ;D
Post by mellow on Aug 31, 2010 17:02:30 GMT 1
;D
Post by bare on Sept 1, 2010 16:46:50 GMT 1
Up to you mate. But there are NO 'extra' parts included. Yama engineers designed it that way, but then what would they know about their engines? I have no idea where the name 'expander' ring originated, but that is NOT it's function. The ring needs No expanding (as if a wee spring could affect ring tension in any real way The thing is there to slow/stop the pistons sideways rock or slap as it changes direction, using the rings contact with the bore as it's anchor. Yes! it works as intended. Engine will also run fine without it.. but increased piston and bore wear will result and ..Noise. will be a problem. Sometimes some of these springs do break in use.. typically of Aftermarket parts but usually when the bore/piston clearance is excessive... beating the pore things to death. Your $ your choices.
Post by mellow on Sept 1, 2010 18:35:06 GMT 1
well i never knew that cheers bare i've fitted it to the bottom ring n e way Cheers
Post by bare on Sept 3, 2010 17:12:41 GMT 1
Great! Sharing errr.. 'hard learned' knowledge is the whole point of this.
