Post by steviep on Aug 28, 2010 18:10:51 GMT 1
Hi. My rd350lc starts fine from cold, but you have to rev the nuts off it to get it to move off and then after about 3 or 4 minutes it stops and i just cant get it started for ages again. Yes i know its tricky to say what may be the problem, but can anyone give me any suggestions as to where i should start looking please? Cheers.
cj
Post by cj on Aug 28, 2010 23:01:48 GMT 1
Was it running OK previously? Whats changed?
Only an idea but have you checked your exhausts are clean inside? If they are clogged it will definately affect your bikes performance due to screwed back pressure and it kinda fits in conjunction with the engine dying when warming up. Good luck CJ
Post by steviep on Aug 29, 2010 6:58:06 GMT 1
Thanks everyone for the advice. I will check them all out. Very much appreciated and thanks very much for taking the timeout to answer.
