Post by mick1664triumph on Aug 24, 2010 18:45:58 GMT 1
Guys going to be having the paint done soon not sure if I should have all the dacals clear coated over or just have the tank one done as standard what do you guys think?
Post by mellow on Aug 24, 2010 19:47:03 GMT 1
Hi mick.............i would.....and did have decals laquered over. u sure u aint got my old F1 ;D
Post by mick1664triumph on Aug 24, 2010 22:04:54 GMT 1
Thanks Guys my anorak is getting bigger ( Green bolts and all )the longer I go on with this bike it is going to be tricky to make my mind up. Mellow m8 it is not yours |Honest ;D
Post by Norbo on Aug 26, 2010 6:28:04 GMT 1
All standard decal are made to be laquered over if you dont over time they will rub of and look crap . If your not laquering over stuff you need to have custom laminated decals for the everything except the laquered tank and they costt double as the laminate costs as much as the vinel to use.
Post by mick1664triumph on Aug 27, 2010 19:49:10 GMT 1
Thanks all, Norbo that is interesting thanks for the info I bought my decals off of a guy on E Bay I think his name was Simon from your neck of the woods? so I assume they will need to be clear coated over ?
Post by mellow on Aug 27, 2010 21:15:03 GMT 1
mr simon5
cj
Post by cj on Aug 27, 2010 22:59:13 GMT 1
anorak me will advise this....... however laminated ones on side panels are far better but then original style.... gaz So there are two destinctive types of decals? are they both available from Norbo?
Post by Norbo on Aug 28, 2010 6:32:26 GMT 1
anorak me will advise this....... however laminated ones on side panels are far better but then original style.... gaz So there are two destinctive types of decals? are they both available from Norbo? I dont stock laminated ones as every one gets them laquered over but i do make them up if asked but they are a little more due to the cost of the laminate .
cj
Post by cj on Aug 28, 2010 8:25:02 GMT 1
I think my anorak has also grown a hood for this rebuild! How much for the laminated decals Norbo?
Post by lcowner on Aug 28, 2010 9:42:33 GMT 1
i got mine of simon5 and are excellent.btw i larquared tank and nothing else.but then again i dont be out much on bike and never will so wont get much wear.hope this helps.it doesent cost much to get them larquared over anyway.6 of 1 and half a dozen of the other m8!!
Post by mick1664triumph on Aug 29, 2010 13:37:13 GMT 1
Talking about anorak I ordered some washers you know the GREEN ones only problem is out of the two bags With the same parts code one was green and one was just zinc plate does this mean Mr Yamaha is stopping the green bits? I have had some electroplated but they never seem the same to me.
Post by mellow on Aug 29, 2010 21:52:55 GMT 1
hi mick.believe i have seen this topic before.seems the green is changing for black on somethings and maybe even zinc
