Post by dredge3 on Aug 5, 2010 22:34:50 GMT 1
Came back from a 5 min thrash....its running in nice now. Power is up and a nittle kick from kick start. Doesnt over heat when the sun is in. Anyway. As I pulled in the drive I heard a rattle...hmmmm.It was the side stand on the exhaust. The nut was quite slack, but that didnt cure it. Its got lc2 pipes on. Its never made a noise before. The stand has quite a bit of play, bit not sure if it should have. If I pull the stand out it clears the pipes. Any ideas.Not a big problem, but it pisses me off ;D
Post by bubba on Aug 5, 2010 23:12:54 GMT 1
mine done the same tryed to tighten but still loads of play the bolt wouldnt pull it any further in, so took it off put a rag around the top to protect it and nipped it up very slighty in the vice then tryed back on the bike nipped it another couple of times to get it with just enough free play then bolted back on and doesnt hit me allspeed anymore.
Post by nikfubar on Aug 6, 2010 9:49:54 GMT 1
Mine was the same & had a thin washer to take up the slack, now removed the washer as I have no issues with it hitting the pipes as I have Gibson GP pipes.
If you want the washer I can post it to you.
Post by dredge3 on Aug 6, 2010 20:50:58 GMT 1
Funny how its just started. Ill have a play when I can be bothered
