Post by chippy28 on Aug 3, 2010 20:48:03 GMT 1
Hi All,when replacing the two center bearings on the crank (250lc)do you press them on so they touch the lab. seal or is there a clearence figure?
Thanks,Andy.
Post by dredge3 on Aug 3, 2010 21:03:17 GMT 1
Its not a diy thing. It has to be pressed by a press and balanced
Post by chippy28 on Aug 3, 2010 21:45:10 GMT 1
Its not a diy thing. It has to be pressed by a press and balanced Yep apreciate that and would also say the same except I have access to presses and all the equipment thats needed to build it myself,it took twelve (12) tons to push the center pin out of the crank using a hydraulic/electric press
Post by chippy28 on Aug 8, 2010 13:00:48 GMT 1
Anyone know the answer?
Post by Tone on Aug 8, 2010 18:33:14 GMT 1
Just had a look in a genuine manual and it doesn't give a figure. Remember that on the LC and powervalves the centre section isn't splined like the aircooled RDs and you will need a jig to make sure it is timed exactly 180 degrees apart. Tone.
Post by chippy28 on Aug 9, 2010 11:36:12 GMT 1
Thanks all for your input,gonna try and build it this week at work as I am on lates Will let you all know how it goes!
