Post by russellwatson17 on Aug 2, 2010 9:03:45 GMT 1
hi there, I've been doing a bit of work on my rd350 ypvs f2 this weekend.
I've fitted an Lc style round front light and cant figure out how i should go about fitting the clocks.
The original F2 clocks are a no-no because they mount on the frame and do not turn with the handle bars where as the new light fitting does.
Does anyone know if the clocks from an LC 31k model would fit directly to an F2 loom? Also, can someone confirm if the clocks on an lc move with the handlebars and how they are mounted?
Cheers
Post by midlifecrisisrd on Aug 3, 2010 8:18:57 GMT 1
Hi,
What you need is a set of N2 clocks and an N2 clock/headlamp bracket. Will bolt straight on to yokes and wiring should be the same. If different you can simply take the wiring out of your clocks and fit in the N ones and yes they do turn with the bars. Look at spending about £100 for them.
Steve.
Post by russellwatson17 on Aug 3, 2010 23:19:01 GMT 1
Cheers, any idea where to find them? Dont seem to be any on fleabay
Post by midlifecrisisrd on Aug 4, 2010 8:09:47 GMT 1
Cheers, any idea where to find them? Dont seem to be any on fleabay The brackets are the rare bit but do come up on ebay every few weeks. 2 sets of clocks were on last week, went for under £50 each. Just keep looking. Steve.
