Post by LC'Adam on Aug 9, 2010 17:40:40 GMT 1
And you get the blasting done for free?? Looks spot on as does your clutch cover mate. Keep up the hard work ;D
grunt
Post by grunt on Aug 9, 2010 17:45:52 GMT 1
And you get the blasting done for free?? Looks spot on as does your clutch cover mate. Keep up the hard work ;D yep anything i want done i pop over to tonys and say hello just doing this and he says ok mate no worries haha all my blasting was free ;D as was all painting on the engine grunt
Post by LC'Adam on Aug 9, 2010 18:43:51 GMT 1
Had an idea for you grunt, put a 350 speedo on your 125 cause its probs gunna need it ;D By the way, did your bike go all the way around the clock in top gear before you pulled it apart?
Adam
grunt
Post by grunt on Aug 9, 2010 18:51:05 GMT 1
yes down hill off the clock flat bout 95-96ish with the mods and standard carb but i got bigger carb and i 175 big bore going on now ;D anyway lol the maximum i should be doin is 70mph ;D
grunt
Post by grunt on Aug 10, 2010 17:17:53 GMT 1
grunt
Post by grunt on Aug 10, 2010 17:35:27 GMT 1
what a difference between the 2 sets of pics. its certainly a one off mate and all your own work too... anyway its no good sat on yer kitchen table get it put back together i want to know how quick she goes when you have run her in. if it were me i would be going premix mate you know for sure you have the right mix then, my old lc kept going pop due to a u.s. oil pump, took me 3 total rebuilds before i gave up n paid for it to be looked at, was a spring somewhere that had to be replaced... anyway rebuilt it n sold it, got just shy of a grand in 2002 god only knows what it would have been worth now days.. well ron at faron said keep the standard oil pump and he was like a talking bible i couldnt belive it i am going to take his advice and he said he has done afew of them now but mainly ones in the standard barrel re lined so i gonna do this first as i need my bike back as i gonna start racing round town again annoying mr plod ;D
grunt
Post by grunt on Aug 10, 2010 17:45:33 GMT 1
right my plan is to turn the minimum stroke up abit so for a start the pump will pump more through then im going to add abit of oil to the tank as well i have spoke to my mechanic tom and he agrees that is should be ok as he had one the same many years ago but i have been thinking will a dt175 oil pump work but i will find out if im wrong it will go bang ;D
Post by mellow on Aug 10, 2010 17:51:35 GMT 1
case looks smart grunt
Post by twostroker on Aug 10, 2010 18:20:32 GMT 1
for what its worth id remove the pump and run premix,my old 175lc that ron did the top end on pulled to the redline in top on standard gearing,a speedo indicated 105mph ish maybe a tad more( a good few mm over 100 anyway),to be honest the motor was faster than what the chassis could handle and it felt dangerous over 75mph imo. i replaced all the swingarm bearings and bushes and it always felt like there was some flex between the frame and swinger under load ??.stretched chains,clutch slip and groved clutch baskets were also a problem on mine but as yours is a full rebuild it should take it better than mine did
grunt
Post by grunt on Aug 10, 2010 18:34:08 GMT 1
i really dont wanna run premix as its to much bother i am going to hunt a dt175 pump as that will give the exact right amount of oil to the 175 cc and that will bolt straight on grunt
grunt
Post by grunt on Aug 11, 2010 10:52:13 GMT 1
off the subject of the engine i know but just come back from doing my bike theory test passed that so now i can finish my full lisence so i can have a 350lc ;D grunt
Post by mellow on Aug 11, 2010 17:44:34 GMT 1
Well done m8 onwards n upwards! ;D
grunt
Post by grunt on Aug 12, 2010 18:29:19 GMT 1
didnt know where to get any from i suppose its gonna be an ebay thing ;D just looked jazzy no idea where to get some from i stick with the black and if some pops up ill get it spoke to my mate who has a dt125 with a 180 autisa barrel he hasnt touched the oil pump but added 50ml of 2 stroke to the tank everytime and he done more than 7000 miles and i didnt seize then he sold it and now has it back and has somehow out a rg250 engine in few more pics of kickstart done today grunt
grunt
Post by grunt on Aug 13, 2010 11:23:57 GMT 1
update : spoke to ron at faron he said the barrel is done and because he had it a little longer than expected and i want it to fly for college he has done something special to it and says it looks good and i will not be dissapointed when i get it together , the head is about to be done and the crankshaft has a little ridge on it and he has some laying around and is going to see if he has one to replace it if not he will keep whats on there as its nothing to serious ;D so all should be back by next friday as it will be completed tuesday and allowing courier delivery time grunt
Post by LC'Adam on Aug 13, 2010 12:39:03 GMT 1
Did he tell you what the 'something special' part was? Any clues lol, you have been lucky with people doing you favors and that grunt. Like the yam logo on ya clutch cover , free paint and now old Ron has something is store, should look and go well when done mate ;D. Adam
grunt
Post by grunt on Aug 13, 2010 15:56:22 GMT 1
no he said he owed me a favour as he has had it longer than expected but he just said you wont be dissapointed ;D
adam i have pm'd you about the carb
Post by twostroker on Aug 13, 2010 16:18:11 GMT 1
no he said he owed me a favour as he has had it longer than expected but he just said you wont be dissapointed ;D adam i have pm'd you about the carb you can get clear plastic float bowls for them pwk28s...very bling
grunt
Post by grunt on Aug 16, 2010 19:52:31 GMT 1
Post by greengoatchoker on Aug 17, 2010 0:31:06 GMT 1
off the subject of the engine i know but just come back from doing my bike theory test passed that so now i can finish my full lisence so i can have a 350lc ;D grunt too much money these days all the old saddo's got em . keep up the good work . this thing will probably be quicker than a 350 in the hand of the arthritus squad
grunt
Post by grunt on Aug 17, 2010 15:16:06 GMT 1
i have got ron from faron engineering doing my barrel which is now complete and norbo has seen it and has said for my money he has done a good tune it should be fast he has spent a while on the barrel work most people i spoke to have had barrel work done with ron which was reasurring
carb is on way thats the next trick thing to finish the engine off nicely
im using my origional micron to see what it goes like atm but eventually i will get a pipe made based around a small can micron like i have but to match the power of the 180cc big bore if it doesnt go as well as expected ;D
Post by racerd on Aug 22, 2010 0:08:59 GMT 1
are you not using reed stopper plates?
Post by racerd on Aug 22, 2010 0:11:32 GMT 1
you can also taper port the front of the carb, the end which goes into the rubber inlet manifold
grunt
Post by grunt on Aug 23, 2010 17:10:34 GMT 1
this carb is outta the window racerd unless anyone wants it £20 quid posted ;D the reeds dont have a stopper plate they are boyseen dual stage racing reeds anyway UPDATE............ parts all back now waiting on 1 oil seal main oil sealr/h side was incorrect then clutch can go in as well as rest of the stuff BIG THANKS TO ADAM for the carb a pwk28 gas flowed and bored to 30mm just waiting on the transparent float bowl and jets,,modded to take auto feed and accept the normal rd cable barrel has had work done by ron phillips at faron engineerring all ports modded many thanks to him piston has had window enlarged and tab out of the bottem crankshaft rebuilt with a silver plated race bearing in big end as well as a racing little end bearing head modded to a 175cc to match the barrel so it has right compression and doesnt have to much and blow up heres the piccys of so far more work to be done tomorrow ;D
Post by mellow on Aug 23, 2010 19:09:38 GMT 1
my engine looks worse than that at mo m8 ;D ur stuff looks real cool ;D
grunt
Post by grunt on Aug 23, 2010 20:59:02 GMT 1
Post by carlos on Aug 23, 2010 21:01:16 GMT 1
WOW!
That is lovely!
Post by blakeseven on Aug 23, 2010 21:11:32 GMT 1
Lovely job Grunt when I was your age I was the grim reaper as far as lc s were concerned wouldnt even have attempted what you ve done let alone pulled it off
Post by billy on Aug 23, 2010 21:29:05 GMT 1
I'm not jelous. Not even a little bit... ;D
grunt
Post by grunt on Aug 23, 2010 22:23:43 GMT 1
