Post by soad1110 on Jun 30, 2010 17:31:07 GMT 1
I have a bit of a slippy clutch on my YPVS 31K! I have set it to drag a little but it still slips when hitting the band unless you feather the throttle on! Is there something i'm not doing or is the clutch gone? If so, what is the best replacement clutch both friction plates and metal plates and where is best to buy it please? If you do a set Norbo, can you please let me know the cost? Cheers all.
Post by bare on Jul 27, 2010 17:06:32 GMT 1
FZ1000 frictions (40% larger surface area)Bin the silly rubber rings if they are still in there as they are less than useless. Steel plates are rarely in need of replacement unless physically damaged and Yama steels are the V best quality.
Post by carlos on Jul 27, 2010 17:22:18 GMT 1
What oil are you using in the gear box?
Post by lcowner on Jul 28, 2010 9:06:31 GMT 1
whats the clucth drag down to-pattern cables,clucth springs,worn out friction plates, ?
Post by Norbo on Jul 28, 2010 11:09:46 GMT 1
I have some real good power plats at £35 and a set of H/D and YZR500 springs should do the job at £17.00
