Post by midlifecrisisrd on Jun 28, 2010 17:09:49 GMT 1
Recently got a set of small can gibsons for my LC2 hybrid. Look great and sound better but want to know how good other peoples fit. Problems as follows:
Left pipe fits better than right but if front pipe pushed up tight to flange the rear mounting hole is too far back and slightly high.
Right pipe if pushed tight up is 10mm too far back and too high for hanger bolt. Both will fit if you pull the front pipe away from the flange 5mm on left, 10mm on right. Worried about stressing the pipes or even worse the barrell bolts. Was worse but better now I swapped the flanges from left to right pipe.
Finally the centre stand stop bracket is 20mm too far back so stand hits pipe.
Any comments welcome.
Steve.
Post by carlos on Jul 31, 2010 14:55:29 GMT 1
My 125 Gibson pipe fits fine! Speak to them and see what they say!
Post by Norbo on Aug 1, 2010 7:31:55 GMT 1
Call them im sure they will fix them . i have heared this a few times with there pipes but will all they make its not suprizing some arnt fitting well .
Post by midlifecrisisrd on Aug 2, 2010 17:10:44 GMT 1
Call them im sure they will fix them . i have heared this a few times with there pipes but will all they make its not suprizing some arnt fitting well . All sorted now, they sent me a set of flanges to weld up myself but I ended up "tweaking" one of the headers. Was bent round slightly too much. They did offer to take them back to sort or replace but I did not want to wait or pay the postage. Sound awesome. Steve
