Post by soad1110 on Jun 27, 2010 10:03:22 GMT 1
Hi, Can any one tell me the length of the dipstick for a 31K YPVS please? I changed the oil yesterday, put 1.4 Litres back in to get a measure of where it sat on the dipstick for a final top up, only to find it was halfway up the blooming thing, so i'm guessing it's not the correct dipstick for my bike!!! If possible, could you let me know the measurements from the flat side that sits on the engine casing to both the bottom and maximum marks so i can set the level properly until i get another one. Many thanks in advance.
Post by scott on Jun 27, 2010 13:18:03 GMT 1
hi m8,length of dipstick is 96mm to 106mm,thats from were it sits on casing to the start and finish of the flat bit that reads oil level.
Post by soad1110 on Jun 27, 2010 15:15:42 GMT 1
Thanks mate, your a star, i'll go and have a measure up shortly. Thanks again
Post by Tone on Jun 27, 2010 18:15:26 GMT 1
Did you run the engine before you checked the level as the oil can sit in the RH side of the crankcase after you refilled it. Also when checking the level have the bike level and upright and check the level with the dipstick resting on the threads i.e not screwed in .Hope this helps. Tone.
Post by soad1110 on Jun 27, 2010 19:15:35 GMT 1
That'll explain it! I've got no carbs on at the mo as i'm giving them a good clean. Checked the level today ans it's fine now, and i have the correct dipstick, which is good news. Thanks for all the help.
