Post by vinze187 on Nov 28, 2005 14:52:29 GMT 1
To make hi level exhausts is it possible that with a set of micron's (or the like ) after the cone expansion bit the end can's are cut off then tube added in and shaped so the cans can be located higher?
Will this have any bad effects how the exhausts work?
Post by Norbo on Nov 28, 2005 16:48:10 GMT 1
If you move a cone around they will still work the same . If you add bits that will make a diferance .
Post by vinze187 on Nov 28, 2005 17:12:46 GMT 1
BOOOOO!!! think i might just stick with normal pipes then for me project
