Post by dredge3 on Jun 21, 2010 21:35:45 GMT 1
After altering nearly all the F***ing wiring, to fit standard airbox. I now have no spark. I had to disconect the cdi unit and reconect it to a decent block connector. It has 4 yellow wires coming up from the flywheel. So I had to mark them and reconect. Its possible they are in the wrong order, but quite sure they are correct. Anyway of testing it. A few bullet connectors came out. And a wire behind the fuse box.Cant find anymore loose wires, so I need to check the ingnition system. If they are yellow and at the stator end the correct colour, then it could be bodged half way. As I had to do some tugging.Anything could have happend. How do I check kill switch is ok...or bypass. How do I check the alternator/cdi/coil system
Post by Norbo on Jun 22, 2010 6:32:41 GMT 1
Wiring i hate it . the only thing i can help with is, disconect the switch gear that will by pass it same for the ignition if its not pluged in its out of the look and the bike should still spark with out them .
Post by soad1110 on Jun 22, 2010 14:32:54 GMT 1
All joking aside, does your battery have a good charge? I have just bought a non runner, replaced the coil because i thought it was at fault, still wouldn't go, gave the battery a good charge as it was next to dead, and now she runs sweet as a nut! Is it possible that as i was kicking all the juice generated was being sucked up by a dead battery?
Post by guiri on Jun 22, 2010 17:10:27 GMT 1
drege, this is a simplified diagram that makes it easy to follow the workings..follow each wire from its source to its destiny and check continuity.....shame i so far away im top dog with the electrics...
Post by dredge3 on Jun 22, 2010 18:51:03 GMT 1
All joking aside, does your battery have a good charge? I have just bought a non runner, replaced the coil because i thought it was at fault, still wouldn't go, gave the battery a good charge as it was next to dead, and now she runs sweet as a nut! Is it possible that as i was kicking all the juice generated was being sucked up by a dead battery? Its not the battery. Stripped harness down and previous muppet left tags on the all white eire, 2 were the wrong way round. No tank on, no battery. 1ht lead. I pushed kick start with one hand and she fired up ;D sorted
Post by dredge3 on Jun 22, 2010 18:55:39 GMT 1
Thanks Guiri. Looked at that in Haynes. One wire to the alternator was a differant colour, The promblem was I had 6 white wires. Previous owner, sure made things hard
Post by guiri on Jun 22, 2010 19:19:04 GMT 1
can be a right git when someone else has messed and you dont know it.
Post by dredge3 on Jun 22, 2010 21:34:18 GMT 1
They even used a block conector from a house. I would say 1920 ish. Those dark brown brittle ones
nickc
Post by nickc on Jun 22, 2010 22:32:16 GMT 1
They even used a block conector from a house. I would say 1920 ish. Those dark brown brittle ones I didn't think bacalite was still available ;D mind you my bike was so bad that you had to press the horn to switch on the ignition and the whole thig had 1 fuse So i'm glad you sorted it out.
