cooler
Post by cooler on Jun 19, 2010 19:36:32 GMT 1
the top feed from the pump that feeds the left carb is pumping some serious bubbles, so much so the line is nearly empty after a 10-20 min spin,,, i've bled the pump and no air in the pump or right carb feed,but plenty in the left carb feed, just got back from said spin so will change the pipe and re-bleed tomorrow, has anyone had owt similar ?
Post by nikfubar on Jun 19, 2010 23:02:39 GMT 1
Strange is the hose cracked and sucking in air faster than the oil is bieng pumped. Surely if there was not enough oil bieng pumped in it would have seized.
