Post by Norbo on Jun 13, 2010 22:44:32 GMT 1
Helpful hints Before building the top end
Make sure all the old gasket has been removed from the bottom of the barrels and your casings using a stanly knife blade them a wipe with wet and dry .Always check to see if the ports have been radiuses as a lot of places who do re-bores don’t radius the ports. " This is cleening up the sharp bits" Always give the barrels a good clean out. As there might be some swarf left over from the re-bore stuck in the transfer ports that could do some damage! Don’t forget to put 2 stroke oil the bores and the pistons before assembly of the top end. Common sense I know, but you would be surprised at how many people don’t.
