Post by treppid on Jun 12, 2010 20:42:06 GMT 1
Hi All. Busy re-assembling my 1990 F2 carbs, new needle valves etc, hit small problem. On the right hand carb, the one without the choke pull, there is an extra pipe spigot, it's on the inside face just below the balance pipe, the left hand carb doesn't have this. It seems to be just a straight drilling into the carb throat after the throttle slide. So what is it for? I don't remember it having a pipe on it, should it, why doesn't it just draw air in and weaken the mixture on the right cylinder? I'm sure someone must know, my Haynes helpfully fails to show it at all!! Any advice gratefuly received...
Post by guiri on Jun 13, 2010 4:20:09 GMT 1
put a photo on mate so we can see exactly what your refering to....
john
Post by dredge3 on Jun 13, 2010 8:33:28 GMT 1
Which model carbs are they too.
Post by mellow on Jun 13, 2010 11:54:11 GMT 1
its the stub for the vacum pipe for the fuel tap innit ;D
Post by dredge3 on Jun 13, 2010 14:32:11 GMT 1
Mellow, didn't you read garry's post?
Post by mellow on Jun 13, 2010 17:02:06 GMT 1
yeah m8.............but i knew the answer and just wanted to post it too ;D
Post by treppid on Jun 13, 2010 21:22:53 GMT 1
Thanks everyone, that explains the other bit of pipe on the fuel tap then, I wondered where that was supposed to go!! Cheers ....
Post by Deleted on Oct 23, 2010 14:25:11 GMT 1
Same pipe caught me out last week too
