Post by rsvr1000 on May 27, 2010 21:53:57 GMT 1
Having running problems at the moment, at low revs and gears bike feels like it is bogged down. at revs above 4500rpm or in 4th gear or higher the bike runs perfect. Bike has been given full service, new plugs, filter, have replaced baffles as they were broken, carbs have been cleaned out, timing has been checked and is spot on, have replaced reed valve blocks as the reeds were not flush with the blocks. Problem seems to be with the left carb more than the right have replaced the float valve assembly but problem still there, any advice would be appreciated, bike is 1981 350lc, Tony
Post by dredge3 on May 27, 2010 22:17:58 GMT 1
If the carbs are set up, balanced etc..check the compression. I did. It didn't have one lol
Post by rsvr1000 on May 28, 2010 18:46:36 GMT 1
Gaz, did not fit carb kit, float bowls are correct, at the moment bike is at bike mechanics being checked he seems stumped as well, might try another set of carbs if some one has got a pair going, Tony
Post by rsvr1000 on Jun 14, 2010 22:20:53 GMT 1
Quick up date, was running way to rich on left hand side, changed main and pilot jets on both carbs. Now running a lot better with a bit messing about, shall leave as it is now, has got a pattern throttle cable on at the moment this shall be changed when i decide to strip it down.Went out with my mate Saturday afternoon on his restored 350lc for its first ride out was really good to get out on the old ones for a change, bikes went well with no issues.
