Post by nikko on Nov 27, 2005 12:16:26 GMT 1
Hi guys , just got a pair of AllSpeed , peinted black . the last owner took a fall and tryed to repair adding a dirty piece of metal on but it STINKS !!
Question :
does some one did ever adapt a other pair of can on AllSpeed ?? cut and weld ?? cut and screw ??
Nikko
Post by Norbo on Nov 28, 2005 16:31:53 GMT 1
I dont se why you could not cut and weld a bit on to the old pipes to fix an end can . But by the time you got a set of cans and welded a bracket on they will nolonger be a bargen . And may well not perform as well as you will have to make the last cone longer to taper of smaller to fit an allloy can.
Post by nikko on Nov 29, 2005 20:51:02 GMT 1
I had a velly good plice my fliend
Nikko
