Post by kiwivini on May 24, 2010 23:11:19 GMT 1
Haynes says 21mm from gasket base. but then goes on to say something about allowing gravity to set the float so that its touching the pin on the valve but not compressing the spring...........
I thort you just laid the carb ventura down on a flat surface so that the float settles than measure it.
or am i being a wally?
81' 250 lc
Can anyone help with my oil pump posting in advice?
cheers,
who would have thort resetting things to standard would be so hard??
arrdee
Post by arrdee on May 25, 2010 8:12:29 GMT 1
Lay the carburettor on its SIDE (not up side down) and when the tab of the float bowl engages the valve needle then take the measurement 21mm (without the gasket in place) Gav
Post by kiwivini on May 25, 2010 12:31:26 GMT 1
Ok by side im assuming you mean the part you will see from the outside of the bike not the front or rear of the carb (inlet or outlet ie the piece that goes into the reedvalve or airbox).
Hope that make sense and doesnt make me look to stupid. ha ha
arrdee
Post by arrdee on May 26, 2010 9:32:51 GMT 1
Ok by side im assuming you mean the part you will see from the outside of the bike not the front or rear of the carb (inlet or outlet ie the piece that goes into the reedvalve or airbox). Hope that make sense and doesnt make me look to stupid. ha ha No dosent make you look stupid at all mate, you are correct in saying that lay the carburettor as you have described (outside) Gav
Post by kiwivini on May 26, 2010 13:44:10 GMT 1
cool cheers for that buddy.
Post by dredge3 on May 26, 2010 22:36:29 GMT 1
Another way is to blow down the fuel inlet pipe. Close floats till you cant blow anymore...then measure. Tricky. Eather way, lay carb on its side, with the dangly end of floats swinging freely
arrdee
Post by arrdee on May 29, 2010 10:45:37 GMT 1
Another way is to blow down the fuel inlet pipe. Close floats till you cant blow anymore...then measure. Tricky. Eather way, lay carb on its side, with the dangly end of floats swinging freely This is actually how I done mine last time as it does give the exact point of shut off on the needle, but didn’t know how to exactly explain it as it was all fingers and thumbs to blow down the petrol pipe and hold the floats at the same time. Tricky but well worth practising! Gav
Post by kiwivini on May 29, 2010 23:40:55 GMT 1
cool will give it a try and let you know how i got on.
cheers fellas
