Post by rich3648 on Apr 22, 2010 22:58:37 GMT 1
my mk3 rd125lc im taking to spain is running hot in uk so a little worried about the hot weather out there.its running on a standard air box,190 standard jet,1 3/4 turns out on the air mixture screw,swarsbrick pipe but runs about 3/4 on the temp gauge. it has a chrome airbox cover i bought of norbo so thinking maybe this may cause a bit of a blockage,it has new air filter put in so not sure why running so hot.any help would be great,cheers
Post by looey on Apr 23, 2010 9:24:25 GMT 1
Was that a "Chrome Airbox cover" or Chrome radiator cover ?. Cos if it's a chrome rad cover, not sure what the design is like on yours but I had one on my 350LC and with it on it ran just over half on the temp gauge and with it removed about a quarter
grunt
Post by grunt on Apr 23, 2010 9:33:21 GMT 1
Was that a "Chrome Airbox cover" or Chrome radiator cover ?. Cos if it's a chrome rad cover, not sure what the design is like on yours but I had one on my 350LC and with it on it ran just over half on the temp gauge and with it removed about a quarter i quite simply drilled mine out abit more but i had same problem mine sits half way now
Post by looey on Apr 23, 2010 10:56:53 GMT 1
Probably worth noting too that the std grill is designed to draw air in which the aftermarket ones aren't.
I have the std rad grill on mine and all the time the bike is moving the temp guage sits just at the beginning of thicker part of the green line (about 1/4 on the gauge I'd say) and that's however hard you ride it.
Given how highly strung these 125's are, I much prefer mine to run 1/4 less on the temp gauge and not have a flashy rad grill (but I am old ;D ;D ;D)
Post by rich3648 on Apr 23, 2010 14:31:26 GMT 1
cheers guys will swap later today and see the difference.
Post by twostroker on Apr 23, 2010 23:22:42 GMT 1
my rd125lc run cooler with no rad guard or belly pan on realy hot days,id defo remove the chrome one in the hotter months if it causes it to run hot and re fit a standard one
Post by rich3648 on Apr 24, 2010 20:24:19 GMT 1
changed today and runs really well and less than half temp. cheers guys took my swarsbrick pipe off and refitted micron power and a set of racing reeds and she pulls really well.all ready for ibiza. thanks again
Post by rich3648 on Apr 25, 2010 19:25:07 GMT 1
done a hundred miles today and plug is a nice golden brown,running below half on temp gauge so all good and bike is running perfect.will post pictures of her at famous points in ibiza in about a week.
