microns
Apr 19, 2010 23:52:18 GMT 1
Post by dredge3 on Apr 19, 2010 23:52:18 GMT 1
Post by looey on Apr 20, 2010 6:55:25 GMT 1
I believe only the rear hanger bolt location is very slightly different and you can see on those pipes that in the past they have been on both types of LC and an extra hole drilled in the hangers to make them fit.
microns
Apr 20, 2010 21:55:28 GMT 1
Post by dredge3 on Apr 20, 2010 21:55:28 GMT 1
Cheers. I thought the manifold was differant
microns
Apr 20, 2010 22:07:52 GMT 1
Post by spondonchris on Apr 20, 2010 22:07:52 GMT 1
No i think the manifolds the same, just the rear mounting is slightly diffrent but you can make LC pipes fit YPVS etc.
Post by bare on Apr 24, 2010 5:10:36 GMT 1
yes those CAN be made to fit an LC . But it requires a wee bit more work than just the offset hole pictured. Took me a couple or three hours of serious fettling with a torch and a cutoff wheel etc. to make mine fit 'perfectly. Had to cut off the rear mount bracket cut a sizable piece off it then reweld it back oat the 'correct' location and an angle that placed it's hole exactly at the mount bolt. Not a trivial amount of work either. Result is they are in tight against the frame, yet not touching anything and the pipes actually fitting into their Head slip joint mounts (and slipping :-) without hanging up or without brute ignorant force being required. The Mounting brackets themselves are too long and at the wrong angle to properly fit those Microns onto the LC frame.. cleanly and neatly. Worth the effort it ...once done.. makes it into a whole new world of quality install As they come from the factory .. they fit on the Bike... but not overly well.
