millo
Post by millo on Aug 5, 2025 18:52:12 GMT 1
Hi guys look if we can put an elsie back on the road. Everything else is piss easy right. I've got an issue with the front brake on my other bike which is a 2018 street triple 765r. I'm having problems with the front brakes. When I'm slowing down to a stop say at lights I get a sort of undulating sort of feeling from the front end through the bars. Please it's not a warped dics *I've checked that) it's sort of like something is oval. The bike otherwise is perfect. I've had the abs checked tyres are spanking new.i really can't think of anything else. Any ideas would be greatly appreciated.
Post by arrow on Aug 5, 2025 19:38:31 GMT 1
You mention the tyres are spanking new. Has this happened since the new tyres have been fitted?
blaine
Post by blaine on Aug 5, 2025 20:07:15 GMT 1
Just to echo arrow, is the tyre seated correctly and the rim true.
I've had it years ago where a new tyre was faulty and air got trapped in-between the plys.
Post by 4l04ever on Aug 6, 2025 9:36:56 GMT 1
Put the wheel on a wheel balancer and have a look.
Post by 4l04ever on Aug 6, 2025 9:38:32 GMT 1
If it only happens under braking, it is probably related to the brakes. Did you change anything before the issue appeared?
Post by stirling11 on Aug 9, 2025 0:15:41 GMT 1
Brake pads loose or missing clips or pins
Calipers loose too maybe
