Post by fraserc on Apr 15, 2010 22:52:00 GMT 1
Anybody got a list of all the bearing sizes, part numbers numbers, manufacturer etc for a 4L0/4L1 ? Crank Mains, Gearbox, Wheels F & R, Water Pump, Headstock (Tapers) Cheers Fraser
Post by oldelsieboy on Apr 16, 2010 7:02:16 GMT 1
Anybody got a list of all the bearing sizes, part numbers numbers, manufacturer etc for a 4L0/4L1 ? Crank Mains, Gearbox, Wheels F & R, Water Pump, Headstock (Tapers) Cheers Fraser All Yamaha part numbers are on the parts fiche available HERE OEB
Post by fraserc on Apr 16, 2010 23:17:27 GMT 1
Thanks, I have this already.
What I was looking for was the bearing manufacturers serial or part numbers so I can go to my local bearing supplier and get the equivalent bearing.
Cheers
Post by oldelsieboy on Apr 17, 2010 8:05:44 GMT 1
usually the last four numbers of the part number are the bearing code mate... Not quite, the bearing code is usually the last number of the first half & the first 3 of the second half, example item 2 below part number is 9330 6- 20420 & the bearing code shown on the description is 6204RS Tapered headstock bearings are not a standard size so are not usually available from general bearing suppliers, but I believe the code for them is SSY-125. HTH OEB
