Post by aaronben40 on Apr 13, 2010 19:12:43 GMT 1
Can anyone tell me their secrets for removing stuck baffles from 4L0 & 4L1 exhausts. I've got the bolts out but the buggers seem to be super glued in!!!
Post by spondonchris on Apr 13, 2010 19:48:42 GMT 1
Take it they wont twist out then, some heat might work maybe a blowtorch and then try and free them, otherwise the only way is to somehow block the baffle ends tight and put a pint or so of summat nasty down the downpipes, maybe caustic soda..........unless anyone has any other ideas.
Post by dredge3 on Apr 13, 2010 22:05:39 GMT 1
While were on the point.Do 31k baffles come out? The shimny end ones. There is a bolt, but looks like a drain plug
Post by aaronben40 on Apr 14, 2010 7:50:08 GMT 1
Thanks for the ideas. The bike is in bits and a long way from running so looks like its tine to get a blowtourch out ;D
Post by Deleted on Oct 23, 2010 14:48:08 GMT 1
Like the sound of the red diesel. will give that one a try
Post by Shytalk on Oct 23, 2010 17:26:31 GMT 1
While were on the point.Do 31k baffles come out? The shimny end ones. There is a bolt, but looks like a drain plug Yes they do, undo the screw or bolt and grip the bar on the baffle with a pair of pliers and twist and pull to remove.
