Post by mellow on Apr 1, 2010 16:46:43 GMT 1
Hi men. While fettling with my F2 this week i noticed the rear exhaust hanger bushes in the footrest hanger are a bit "sloppy" for want of a better word. As im goin to be removing the exhausts soon to give them a damn good sealing up i wondered if anyone has any hints/tips for removal and refitting Im thinking use my dremmel to take out a bit of the metal of the old bush then peel it away with screwdriver or summin Then try and press in using a vice without snapping the hanger
Post by Shytalk on Apr 1, 2010 20:09:04 GMT 1
I cut the rubber bit out then use a junior hacksaw to cut through the metal ring, a dremel is a bit too quick - easy to go into the hanger. Chuck the new bushes in the freezer for a day or more before you need them, then as mentioned; use a socket and a vice to press them into position after greasing the bush edge / rim first.
Post by mellow on Apr 1, 2010 22:09:54 GMT 1
Cheers for the replys guys......really lookin forward to doin this now lol ;D
Post by mellow on Apr 4, 2010 12:10:02 GMT 1
Ok cheers gazza ;D Hope all this heat and grease dont make too much mess of my shiney hangers Im so wishing i didnt have to try this coz i just have a feeling its gonna be a b*****d pig of a job ;D
Post by mellow on Apr 4, 2010 12:26:44 GMT 1
Why didnt u say that earlier...............just been down to the army surplus store ;D
Post by mellow on Apr 4, 2010 21:43:02 GMT 1
I have a small piece of info now.............whilst scouring the net...........apparently plumbing shops sell cans of liquid nitrogen which are handy for freezing things like bearings etc before fitting
Post by mellow on Apr 24, 2010 15:13:35 GMT 1
well.........................its out new bush is in freezer..................will try n press in tomorrow
Post by mellow on Apr 25, 2010 12:18:25 GMT 1
Well........................................... that went surprisingly easy. No problems at all.something should of gone wrong
Post by bare on Apr 27, 2010 3:16:14 GMT 1
I have a small piece of info now.............whilst scouring the net...........apparently plumbing shops sell cans of liquid nitrogen which are handy for freezing things like bearings etc before fitting Are you sure? Had a Liquid Nitrogen cannister in a metalurgy / lab class once. It's a really big vacuum bottle affair 100cm x 70 cm..likely worth as much as an automobile. It takes a serious container or pressure vessel to hold Nitrogen in a liquid state.. and Briefly at that. Also this is a very hazardous material, possibly one would need Papal dispensation to just buy some, outside of laboratory uses. Seems a bit of overkill to patch a toilet ?
Post by mellow on Apr 27, 2010 17:14:22 GMT 1
thats wot i read somewhere m8 lol jobs now n e way
