Post by philmill on Sept 15, 2024 10:59:03 GMT 1
What master cylinders are people using on their Hybrids? I put a Brembo on but the lever will go back to bars without too much effort, it stops ok but I think the Master Cylinder is too big/powerful for the 4 pot GSXR calipers. I am thinking to got for something like an R6 but thought I'd see what you guys are using. I liked the Brembo as it looks the part and in keeping with the whole Hybrid look. What ever I use I need to match a clutch perch and lever with it.
Thanks, Phil
Post by Tobyjugs on Sept 15, 2024 11:13:53 GMT 1
Hi Phil you need to find out what bore size is used with the original master cylinder for those calipers. When you know this you can search the Internet or get a better informed reaction from forum members.
Post by dodgyknees on Sept 17, 2024 20:05:27 GMT 1
Mt-10 on mine
Post by lcmarky on Sept 18, 2024 8:08:46 GMT 1
I put a HEL on mine as you can get the clutch lever assembly to match. It's a seriously good bit of kit & HEL are ace to deal with.
Linked to MT09 calipers it stops quick!
Post by lcmarky on Sept 18, 2024 8:10:15 GMT 1
This should give you a better idea, but I can take more pics if you need them.. 21st July 4 by KTM Marky, on Flickr
